stud removal
doghunter9
looking for a trick that will get the stud out of my cylinder block. it is not broken or coroded. I put two nuts on it and lock them together then tried to turn it out but the two nuts are turning together and the stud stays put.
Any ideas? dont want to put heat there, affaid to dammage it.
Scott
Re: stud removal
How about using a pipe wrench on the stud? You will not be able to reuse it, if you mess up the threads.
doghunter9
Re: stud removal
i never really tried anything like that, i was just trying to get it of with out damage, I guess a stud should not be that hard to get.
bustermin
Banned
Re: stud removal
You can purchase a stud remover. It is a socket looking tool that fits over the stud and tightens down on the stud as you turn counterclockwise. It will only do minimal damage to the threads (unless you really torque it) and then you can run a die down to repair the threads.
Bifflefan
Re: stud removal
Scott
ive had to use 3 nuts b4. just remember to remove them using the bottom nut.
doghunter9
Re: stud removal
thanks guys its out used vise grips and alittle propane.
