_chris_
- Joined
- Jul 9, 2009
- 439
OK I just picked up a new boat yesterday and I think it may not have the right prop but I could be wrong. Here is the answers to your questions. And I believe the prop is SS but I don't care if I stick with it or not.
1. Year, make and model of boat
1993 Four Winns 190 Horizon LE
2. Length, width and base weight of boat, look for boat decal on back of boat
20.08' long, 7'4" Beam, 2640 LBS
2a.What is the recommended HP for your boat
190
3. Number of people and gallons of gas normally on boat
3 people and 35 gallons fuel
4. What do you use the boat for
Cruising, skiing and tubing
5. Is it a Deep Vee and if so how many degrees of deadrise
18
6. Year, make and model of motor
1993 5.0L-HO/V-8
7. HP and gear ratio of motor IMPORTANT
190 1.59:1 Gear ratio
7A If you have a mercruiser and don?t know the ratio get your serial off the outdrive and go here http://www.sterndrives.com/mercruisersterndrives.html
8. Manufacturer?s recommended Wide Open Throttle (WOT) range
4400-4800 or 4600-5000 not sure which one
9. Anti-ventilation Plate height above keel of boat if it is an outboard in inches
10. Is it a bass boat or does it have a pad bottom
No
11. Does it have a hydrafoil, dolefin or trim tabs
No
12. Make, model, diameter, pitch and whether SS or aluminum prop
14-1/4 x 19 SS
13. WOT RPM and speed from your current prop and how much gas and how many people were in the boat for the test data and is the speed by GPS. If you do not have a tach you can buy a Tiny Tach for $ 50
3 people 35 gallons fuel WOT 46 MPH at 4800 RPM w/ outdrive trimmed up
3 people 35 Gallons fule WOT 42 MPH at 4800 RPM w/ outdrive down all the way
14. Are you at sea level or a higher elevation, give us the elevation in feet
1100
15. Has your motor been tuned up lately and have you checked that the carburetor butterfly is opening all the way, checked compression, and looked at the plugs and checked spark, all of the forgoing could be the reason your prop is not attaining full RPM
PO says it was tuned in March Engine has 177 hours on it.
16. How long has this prop been on the boat and why, at this time, do you think it is the wrong prop
Since I got the boat yesterday but from reading it was supposed to have a 21 pitch new.
17. Does the prop show any damage that you can see
No
18. What problems are you trying to cure or what are you looking for the boat to do that it is not doing the way you think it should or to your expectations
Just want to make sure things are right.
190
18
1993 5.0L-HO/V-8
No
No
14-1/4 x 19 SS
1100
No
