mercury 115 prop size question
the big e
I have a 1980 mercury 115 on a 14.5 sunray runabout, has a 21p on it now and tops out at 5500rpm, 50mph, it works good with two people and a light load, any more and it bogs out of the hole. Is my motor getting weak or would a 19p prop be a better choice?
hwsiii
Re: mercury 115 prop size question
E, I am showing a 22% slip if your gear ratio is 1.7:1 and a WOT RPM of 4,800 to 5,300, please verify this. And that is exceedingly high for that boat and motor. If you change to a 19" pitch in that same make and model of prop your RPM should rise to about 6,079 RPM. If my information above is correct it appears to me you are running the wrong blade geometry in that prop.
Please fill this out for me.
Iboats Boat and Motor Info
1. Year, make and model of boat
2. Length, width and base weight of boat, look for boat decal on back of boat
2a.What is the recommended HP for your boat
3. Number of people and gallons of gas normally on boat
4. What do you use the boat for
5. Is it a Deep Vee and if so how many degrees of deadrise
6. Year, make and model of motor
7. HP and gear ratio of motor IMPORTANT
If you don?t know the ratio, you need to pull the plugs out and put a piece of tape across the prop and the lower unit and then cut it between the prop and the housing and turn the motor until the tape lines up with each other, it is easier if two people do this, so one can watch the prop while the other counts the revolutions of the motor
8. Manufacturer?s recommended Wide Open Throttle (WOT) range
9. Anti-ventilation Plate height above keel of boat if it is an outboard in inches
10. Is it a bass boat or does it have a pad bottom
11. Does it have a hydrafoil, dolefin or trim tabs
12. Make, model, diameter, pitch and whether SS or aluminum prop
13. WOT RPM and speed from your current prop and how much gas and how many people were in the boat for the test data and is the speed by GPS. If you do not have a tach you can buy a Tiny Tach for $ 50
14. Are you at sea level or a higher elevation, give us the elevation in feet
15. Has your motor been tuned up lately and have you checked that the carburetor butterfly is opening all the way, checked compression, and looked at the plugs and checked spark, all of the forgoing could be the reason your prop is not attaining full RPM
16. How long has this prop been on the boat and why, at this time, do you think it is the wrong prop
17. Does the prop show any damage that you can see
18. What problems are you trying to cure or what are you looking for the boat to do that it is not doing the way you think it should or to your expectations
19. If you are trying to attain a better cruising speed and fuel savings or trying to attain a faster speed I will want you to take your boat and run it with 1 or 2 people and give me the RPM and speed readings starting at 3,000 RPM in 500 RPM increments all the way to WOT.
REMEMBER, The numbers I give you will be NO better than the information you give me
The only thing I ask of you is to come back and give me a report of WOT RPM and speed for my database.
H
the big e
1. 1979 sunray 14.4
2.?
3. 70hp
4. 4 people. 50L gas
5.?
6. 1980 mercury 115 l6
7 115hp stock gearing 2:1 i beleve
8. 5600 rpm?
9. no
10. no
11. it has doal fin helps it out of the hole a bit don't like it otherwise
12. 21p ss
13.5500rpm, 50mph according to a friend on a maxed out sea doo that could not pass me, three people 50L gas
14. sea level
15. motor tuned, 20psi low on one cyl.
16. on when i got it last year, worked ok, want better for pulling wakeboard and such
17. no damage
18. hole shot
19. need to get gps
the big e
pic
hwsiii
E, this is the prop that I recommend the following prop in a 19" pitch to raise you RPM to about 5,700 RPM for running with today's gas. It is a 4 blade and will worky very well for pulling skier and toys and will improve your hole shot and acceleration. You can buy it right here at Iboat.
Price: $124.98 You Save: $19.97 Compare: $144.95 Discount: 13.8% Off
Propeller Specifications:
SKU:prop #9413-125-19Hub #RBX-102
Manufacturer: Solas
Brand: RUBEX 4
Material: Aluminum
Diameter: 12 - 1/2?
Pitch: 19?
Blades: 4
Rotation: Standard (Clockwise)
Usually Ships Within: 1 Business Day
Product InfoShipping InfoReturn Policy About Solas Boat Propellers
RUBEX 4 Aluminum Boat Propellers
Exclusive Solas squeeze casting process
Wide blade design specifically for 4-stroke engines
Outstanding acceleration and top speed
Solas Aluminum High Performance RUBEX Interchangeable Hub Propellers
Interchangeable with Flo-Torq & Vortex Systems
H
