throttlejunky
Thread starter- Joined
- Aug 4, 2009
- 6
1984 Wellcraft 210 Elite.
3000 lbs.
Mercruiser 5.0 228hp. I think that means alpha 1.6 ratio
Aluminum 3 blade 14x16 prop. Possibly cupped, can?t tell bye eye.
Manufacturer recommended rpm range= 4200-4600 WOT
Need to get a new prop. Having trouble figuring what pitch because of an issue. Right now, the current prop has cavitation burn, 2 small tears that are dime size. I know this will rob MPH?..but what about RPM? Right now with a 16? prop I can only turn 4200 rpm for 31 mph. Feel like I should turn a 19? pitch at 4200 hitting low to mid 40?s, unless I am just delusional. Boat launches hard, motor strong. So is my damaged prop not only slipping more and affecting MPH, but also keeping my engine a good 600 rpm low? Feel the 16? pitch should be hitting beyond upper rpm range, possibly 4800 if I let it wind. What do you think? Dont want to throw a 19 on her if it won't work. You guys see rpm's drop from prop dings/bends? Thanks to all who chime in!
3000 lbs.
