jporter5333
Thread starter- Joined
- Jul 27, 2009
- 28
I was putting around at about 1/4 throttle when I took off, the boat didn't seem to run up the rpm's like it should and died pretty quickly. Restart it but it won't run up rpm's in neutral and it dies when I engage the drive. Finally just gets to where it won't even start. Get home and there is no spark to the plugs. Replace plugs and wires still nothing. I have checked the stator and the trigger and they ohm out ok. I also didn't show any voltage to the coils so does that mean it is the switch box?
Another problem I have is when I took the fly wheel off I didn't realize that the fly wheel and the hub were in two pieces. So when I bolted it back up I'm pretty sure I got the fly wheel turned wrong. To fix it I brought the top piston (#1) all the way to the top and assumed that that was tdc. Then I unbolted the fly wheel from the hub and turned so that the zero timing mark on the fly wheel lined up with the index mark. If that's wrong I would appreciate some help with that too.
Thanks
Thanks
