how do you replace the throttle cables in the control box?
M mattsylvan Seaman Thread starter Joined Sep 1, 2008 Messages 52 Aug 4, 2009 #1 how do you replace the throttle cables in the control box?
E Eshaw150 Petty Officer 1st Class Joined Nov 30, 2008 Messages 295 Aug 4, 2009 #2 Re: throttle cable help we need the info on the motor
M mattsylvan Seaman Thread starter Joined Sep 1, 2008 Messages 52 Aug 4, 2009 #3 Re: throttle cable help whoops sry on 1980 johnson 75hp and is their a way to at least adjust the cables because i have to push the throttle arm way past where it should be to get WOT and i was thinkin just to replace the cable
E Eshaw150 Petty Officer 1st Class Joined Nov 30, 2008 Messages 295 Aug 4, 2009 #4 Re: throttle cable help inside the box there is a plastic sleeve that has a alan screw on both sides the the sleeve will slide off
