I recently had the original block replaced with a Mercruiser long block- supposedly the identical block to the OMC. It was a fairly easy conversion- a simple "drop in." We used the original carb which was a 4bbl. The original engine was rated at 205 hp.
I am puzzled because the remanufactured Mercruiser block seems to indicate a hp of 190.
My question is this. Is the Merc block internally identical to the OMC I had or not? The OMC Cobra had two package variations at the time, one with a 2bbl and one with a 4bbl, and I wondered if the 4.3L engines were in any way different internally, in which case the Merc block may not be quite right. I can't find any data that says the original 2bbl was 190 and the 4bbl was 205, or any suggesting subtle engine differences between the two.
Thanks for your help. The bottom line is that I hope my new package is giving me 205 hp not 190.
Frank
Frank
