New boat first step? Stringers? w/pics
nytony11
I just got a 1977 open fisherman, The hull and transom are great the floor is removed and half of the front stringers were bad, What is the first step for putting in the stingers? A beginner at this so any help would be apprieciated'
More pics available
nytony11
Re: New boat first step? Stringers? w/pics
There looks like only had two before. Should i do 4 and should I run a few side to side?
D.spencer
The first step? Convince yourself it won't take more than a month or two- tops..... and it won't take much money.... and you can do it on the cheap.... and you will surely not do a full resto....you allready have every tool needed....friends will help out when you need them most.....the weather and temperature will obey your every command....supplies will arrive in a timely matter and not after the weekend you have available-same with money for the project....there will be no "learning" curve.... not trying to scare you just a realization of facts-thats all....:D
nytony11
Thanks Spencer im starting to get that feeling lol
lowkee
two stringers should be enough. I would add a bulkhead (side to side wood) every four or so feet, though, just to be safe. You don't want to be doing this again any time soon ;)
nytony11
thats what I figured. Now do i rest the sole on the hull where it come to a point or should I make a brace and glass it into the front?
nytony11
The area in pic
