Re: 1960 lark 2 40 horse problems (updated w/pic)
Well the prop will be back from the shop next friday. I am considering buying a used one just to keep as a spare in case I get into this situaton again (I sure hope not!). So whould the pin that is in there shear (if it is still the stainless one?).
I'm thinking about how the engine cut out momentarily on a cylinder, and then once the power was reduced for a few seconds, it came back in again. Is it possible the run-away/over speed switch could be faulty? I think next time I'm out I'll try disconnecting the lower mag wire from the switch and see if it does it again. If not, I'm going to suspect the cut-out switch was kicking in for some reason.
I just had another idea. If that prob was spinning on the hub, the overspeed may have kicked in to prevent the engine from over-reving??
