bigblue16.5
- Joined
- Aug 13, 2009
- 5
Re: 71 Merc 800 Outboard Fires, starts, Roars and then dies instantly?
Not to beat a dead horse, but did you try hooking your fuel line directly to the fuel pump bypassing that one way valve(I NOT TALKING ABOUT THE BULB), the valve is bolted to the engine. This is the easiest test and free. I may be a noob to outboards but not engines in general. I don't think this is a carb issue. This one way valve is what the fuel line slips onto on the engine. I think I am supposed to have a part on the fuel line from the tank that locks onto this valve by rotating it. I probably should have told you that my engine is a Mercury 500 with super thunderbolt on the block, haven't checked the year but I think it is a 72. It is hard to beleive that two seperate conditions could cause the exact same problem on engines that are very similar models and years.
PLEASE PLEASE PLEASE I begging, try this before you spend any more money or time on the engine. Its FREE and only takes seconds. If you want I can post the pictures of everything. I feel for you, there is nothing worse than missing out on good boating weather. Good luck.
