2000 Johnson 50hp j50plssm. After experiecing enging trouble a couple weeks ago (stalling at idle with no restart) I took it to the shop for an engine check. Compression good, spark good, fuel good, this is what they said. They suggested a carb rebuild an tune up for $595. I picked the boat up and did the rebuild myself. All seemed good on the hose. Took it to the lake and basically had the same problem; fine at top end, stalling at idle and unable to start. I did somehow figure out that if i tilted the motor up with the exhaust out of the water it started fine. I did this at the dock multiple times, at idle, let it start to stall out, tilt motor up, engine comes back. So it basically runs better with no pressure on the exhaust. (Im assuming thats what it is) When it is not having the problem it idles fine, I have it about 1000-1100 in neutral. Any ideas? Could this possibly be a fuel pump issue?
Thanks in advance for the help, I need it.
Steve
Steve
