Starter Problem? 89' 140vro
lori77563
We replaced the fuel pump and rebuilt the carbs and it ran just fine, only took it out a couple of times. Sat unused for 4 days now the starter barely turns the motor over. Both batteries were checked and are good. Starter gone bad??
nymack66
Re: Starter Problem? 89' 140vro
Remove the battery and bring it to any Marine or Auto store they will load test it for free and verify a full charge if all pans out ok then verify all your battery connections are LUBE and tighten correctly.
Is your engine equiped with a solenoid ? If yes this can be the problem also ..
lori77563
Batteries have been tested and r good. Solenoid appears to work as the starter will turn but just barely. Goes uh,uh,uh,uh,:)
countvlad
before you change the starter try to start it without the solenoid.... if no change time for a new one....
LIQUID PROZAC
clean connections at starter and then tap on side of starter lightly as you try to start if it engages then replace starter
