MossyOak99
Thread starter- Joined
- Aug 18, 2006
- 25
Ok. I am stumped. Had the boat out last week and it ran normal. started right up ran good no problems. Decided to go ahead and fire it up today in the driveway to check it out before tomorrow mornings fishing trip. I changed out the alternator belt so wanted to make sure everything was working. Well, that's where the trouble started.
This is a 1987 Mercruiser 120. Hooked up the hose and started running water, turned the key and nothing. made sure the boat was in nuetral and tried again, nothing. checked the battery voltage and it was good. Even ran it to the auto store to have them put it on a tester, tested great. Came back and started looking under the dash, noticed that there was power to the ignition switch untril i turned it to run then the power went out to everything under the dash. Figured that the switch was bad so went and got a new marine one and installed it. Getting power all the time now. When key turned forward there is power to the gauges but the don't light up or move at all. Also, when I try to start it I still get nothing. No clicking, no anything.
Sorry so long but I don't know where to go from here.
