northernmerc
Thread starter- Joined
- Apr 6, 2009
- 401
This is on a 2000 model Johnson 30 2 cylinder two stroke.
After extensive diagnosis, it was determined that the motor was overheating. Overheating causes the overheat sensor to cut back the RPMs until the engine cools. (The motor surges but will not build RPMs again until it cools. It has been determined that this is not a fuel problem and that the engine is overheating.)
The Johnson dealer replaced the water pump, thermostat, and overheat sensor. That has not fixed the problem. It does exactly the same thing - surges and will only idle until motor cools. Water flow out the indicator tube is good. Compression is good.
The dealer seems to be out of ideas, so I'm hoping someone here can help with this.
After doing some research (including looking through the repair manual), several possibilities stand out.
- leaking head gasket that overheats the water and/or allows compression gases to escape into the cooling water jacket.
-blockage or other water flow problem in the water jackets around powerhead. This motor has only been used in fresh water and shows no signs of corrosion.
Can anyone tell us what diagnosis procedures to follow to determine if head gasket needs replacement? Or is this a case of taking it apart and replacing the head gasket and hoping for the best?
And how and where would one look for and fix a blockage in the powerhead area?
