bulb will not stay pumped up
bpd605
Hi, I have a 1979 Evinrude 70 outboard and the fuel bubble will not stay pumped up. I have replaced the bubble and the fuel line as well as the tank but still have the same problem. The engine will run at idle for about 3-4 minutes before starting to cut out and you can pump the bubble and it will keep running. Can anybody help me with this?
Blade_Link
Re: bulb will not stay pumped up
you need a new fuel pump or there is air getting in the gas line make sure that the clamps are tight on both ends and check your fuel pump theres your cause
countvlad
agree ^^^^^
