stephanofd
Thread starter- Joined
- May 30, 2009
- 17
Hope a few of you can help me with this. Local prop shop says I have the right prop but after reading some of the great info here, I'm not so sure.
Iboats Boat and Motor Info
1. Year, make and model of boat
1993 Celebrity 180 Status
2. Length, width and base weight of boat, look for boat decal on back of boat
18', 91" beam, 2500 lbs base weight.
2a.What is the recommended HP for your boat
175
3. Number of people and gallons of gas normally on boat
2 adults, 2 children, assorted gear ~ 700lbs + 25 gallons of gas
4. What do you use the boat for
Some cruising, mostly towing and skiing.
5. Is it a Deep Vee and if so how many degrees of deadrise
It's a Vee hull, couldn't find the deadrise, if anyone knows, please share.
6. Year, make and model of motor
1993 4.3L LX Mercruiser
7. HP and gear ratio of motor IMPORTANT
175 HP, 1.81:1
7A If you have a mercruiser and don?t know the ratio get your serial off the outdrive and go here http://www.sterndrives.com/mercruisersterndrives.html
8. Manufacturer?s recommended Wide Open Throttle (WOT) range
4400 - 4800
11. Does it have a hydrafoil, dolefin or trim tabs
Stingray foil, no tabs.
12. Make, model, diameter, pitch and whether SS or aluminum prop
Currently Quicksilver 14 1/4 x 21 SS 3 blade
13. WOT RPM and speed from your current prop and how much gas and how many people were in the boat for the test data and is the speed by GPS.
WOT is 5400 RPM's GPS speed is 41.5 MPH.
14. Are you at sea level or a higher elevation, give us the elevation in feet
297 ft.
15. Has your motor been tuned up lately and have you checked that the carburetor butterfly is opening all the way, checked compression, and looked at the plugs and checked spark, all of the forgoing could be the reason your prop is not attaining full RPM
Engine was tuned in June 09, compression on all cyl's in 160 - 175 range.
16. How long has this prop been on the boat and why, at this time, do you think it is the wrong prop
Just bought the boat in June, it came with it. The RPM's are exceeding the high range for this motor. I don't have a problem holding back on the throttle, this prop gives me pretty good hole shot, it can be on plane in ~ 10 seconds. I would like to buy a spare prop and would like to know which way to go. Was thinking 4 blade 23 to get my RPM's down and keep my hole shot. Not worried too much about TS.
17. Does the prop show any damage that you can see
It's clean and sharp.
18. What problems are you trying to cure or what are you looking for the boat to do that it is not doing the way you think it should or to your expectations
See # 16.
Thanks for any help you guys can give me.
175
175 HP, 1.81:1
4400 - 4800
297 ft.
See # 16.
