Re: 196? Crestliner Mustang? Resto begins Help needed
Alright just a small update. I've removed most of the glue on the sides via grinder and cut the stringers back a bit to allow easier access to the transom. I prepped the transom surface and I'm getting very close to putting the new transom in. I cut the new transom pieces out and I'm in the process of putting the two pieces together. I did make up some of Ooops super duper PB to fill some spots on the transom skin and the new transom had a few spots that needed filler. I ran outta time to put it together but I'll get that done this week! The poly resin didn't smell as bad as I was expecting. I've worked in industrial wastewater treatment for 15 years and have smelled worse things LOL.
I do have a couple questions.
1. I have cabosil, 1/4 chopped strand and 3m glass bubbles. If I'm just filling surface stuff do I need the 1/4 csm in there? (I'll use it when filling the spots around the transom and filleting.)
2. If you look back at the pics I've posted you can see 3 drains. Garboard, transom and one more that use to drain the floor area. I'm thinking about building a bilge area now that I have that section cut out. Do I still need that deck drain? kinda seems pointless now?
Ok on to the pics I built a motor stand using the instrucions on iboats. Came out nice and sturdy. I haven't put the castors on yet but I have them and will.
A little PB (looked likes PB too lol)
Couple shots of the new transom.
Preparing the CSM
Forgot to go out and take a few of the hull but I'll get those in the next update. Hopefully the transom will be in!
