I have a 14ft 1960 Sea King fiberglass boat. I believe it's what they call a flat bottom boat or jon boat.
I have a 1968 mercury 50 horsepower thunderbolt outboard for my motor.
Motor runs great, boat floats.
Here are pictures of boat and motor to give you guys an idea of what i have.
http://i32.tinypic.com/15i6uyp.jpg
http://i31.tinypic.com/2j6a80p.jpg
http://i25.tinypic.com/2uo11ys.jpg
First - When at higher RPMs I get quite a bit of water spraying behind the boat.
Here is a short video of the spray in action.
http://www.youtube.com/watch?v=CapA3DviUy8
now, I had a problem with spray AND water coming over my motor hinge (diagram in pic http://i27.tinypic.com/10ru3it.jpg - not my motor but shows you how water was coming over) but I was able to fix that by moving my manual trim settings to the second to last hole away from the boat, now I don't get water over the hinge, but I still get all that spray.
My Cavitation plate at that trim setting sits about 1" - 1 1/4" below the bottom of the back of my boat.
Also, when I am at WOT my boat tries to turn to the right by itself and will start listing to left or right side randomly. If I go to WOT, get up on plane and then throttle back down a bit I can hold pretty steady, but she still feels a bit unstable, it definately turns to the right a lot easier than to the left.
Any suggestions on fixing these problems? I imagine smart tabs would help with the listing left and right at WOT but the water spray (as far as I know) shouldn't be like that I think.
But I am pretty new to boating, this is my first boat, I took that motor which hadn't run in 6-7 years and got it going strong (new impeller - rebuild fuel pump, cleaned, etc..) and would like to get her running smooth on the lake.
