harleyfool
Thread starter- Joined
- Jun 7, 2009
- 35
Volvo 4.3 GL - year 2000 - Carb
As noted in an earlier post, no water flowed thru the engine when I used muffs in an attempt to flush cooling system. Suspect that impeller/sea pump has given up the ghost. Ordered an impeller kit as a starting point. Several questions.
Assuming the impeller disintegrated where did the bits go? I assume that once the sea pump housing is off I can run water from the muffs thru the stern drive and flush the up stream portion of the cooling system. How to flush debris from the down stream portion of the cooling system??
