capt. kirk
- Joined
- Aug 5, 2009
- 5
Well, just picked up my first boat last weekend from Valdez. It's in great shape and well worth what I paid for it. It has twin VP engines which the marine survey calls 250 A/SP which I beleive are the AQ151 engines. They both run fine however one oil pan has a rust pin hole and the other pan is rusting but not yet leaking. I'm going to pull the engines next spring and replace or repair the pans as well as perform some of the other routine maintenance while I've got the engines up. My questions(I asked this question last week but was mistaken as to the engine type): Is there an automotive equivalent to these AQ151 engines? I'd like to be able to find a couple pans from the wrecking yard and buy the appropriate pan gaskets from the parts store.
While I have the engines out I plan on replacing the timing belts and servicing the raw water pump and just basically clean things up. Are these timing belts marine specific or will an automotive belt work?
If the exhaust and drive shaft bellows...and the raw water "S" hose look fine and are still flexible should they be replaced anyway? I don't know how long they've been on but from what I can see they look fine.
Thanks for your help
Kirk
Kirk
