Re: 1956 gale
I bought a 1956 gale,Since then I rebuilt the carburator,cleaned the points,changed the gas pump and foot.I put it in the water and it dosen t do more than 2miles\hr.i brought it to 3 mechanics and they all said the pitch of the propeller.I ve changed that 3 times and still no difference.Nobody has an idea,or what the pitch of the propeller is supposed to be.Why isn t it going any faster?
You did pull in the anchor, right? Hey, just kidding.
But seriously, you need to clarify the question/problem.
How big is this motor? Since it has a fuel pump, we know it is bigger than a 3hp.
Is the motor racing and not going anywhere like spinning your wheels on the ice? That would be a spun propeller hub (or broken shear pin). But a 5hp doesn't have a rubber propeller hub. 12hp -up does.
OR...is it just doggy and won't rev up like you aren't giving it enough throttle? Well maybe you aren't. Check to see that the linkage does indeed open 'er up.
However, I'm guessing that it is running on one cylinder. That is the cause of 99% of no-power problems.
One last comment--if it is a 5hp with full FNR gearshift, and it very tight to crank and turn over, that is a broken shock absorber in the lower unit.
Prop pitch???? Either you mis-understood what they told you, or nuts and phooey. No way.
