Low Rpm On My Brand New Engine Force L Drive 1992 Bayliner Capri
L DRIVE 1992
I have 1992 20 fit Cudy Caben Bayliner Capri
Inboard Force 120hp L Drive Boat. I just installed
brand new Engine NOT Rebuild and my RPM on full throttle is 3500.
Speed is 35 miles. Recommended RPM Operating Range
is 5000-5500. My prop is 13-17 CAN ANY ONE HELP???
THANK YOU!!
steelespike
Re: Low Rpm On My Brand New Engine Force L Drive 1992 Bayliner Capri
There is no way you could do 35 at 3500 rpm.Is the speed by gps?Speedos are pretty inaccurate.But I would suspect the tach first. Speedo would have to be off by about 10 or 15mph,not likely.
hwsiii
L, welcome to Iboats prop forum and we will try to help you as much as we can but without more information no one can help you, and I will tell you I need more information than anyone else. But if you would like my help fill this form out and I will help you as much as I can, if you would prefer to not go to this much trouble there are other people who will help you.
Iboats Boat and Motor Info
1. Year, make and model of boat
2. Length, width and base weight of boat, look for boat decal on back of boat
2a.What is the recommended HP for your boat
3. Number of people and gallons of gas normally on boat
4. What do you use the boat for
5. Is it a Deep Vee and if so how many degrees of deadrise
6. Year, make and model of motor
7. HP and gear ratio of motor IMPORTANT
If you don?t know the ratio, you need to pull the plugs out and put a piece of tape across the prop and the lower unit and then cut it between the prop and the housing and turn the motor until the tape lines up with each other, it is easier if two people do this, so one can watch the prop while the other counts the revolutions of the motor
8. Manufacturer?s recommended Wide Open Throttle (WOT) range
9. Anti-ventilation Plate height above keel of boat if it is an outboard in inches
10. Is it a bass boat or does it have a pad bottom
11. Does it have a hydrafoil, dolefin or trim tabs
12. Make, model, diameter, pitch and whether SS or aluminum prop
13. WOT RPM and speed from your current prop and how much gas and how many people were in the boat for the test data and is the speed by GPS. If you do not have a tach you can buy a Tiny Tach for $ 50
14. Are you at sea level or a higher elevation, give us the elevation in feet
15. Has your motor been tuned up lately and have you checked that the carburetor butterfly is opening all the way, checked compression, and looked at the plugs and checked spark, all of the foregoing could be the reason your prop is not attaining full RPM
16. How long has this prop been on the boat and why, at this time, do you think it is the wrong prop
17. Does the prop show any damage that you can see
18. What problems are you trying to cure or what are you looking for the boat to do that it is not doing the way you think it should or to your expectations
19. If you are trying to attain a better cruising speed and fuel savings or trying to attain a faster speed I will want you to take your boat and run it with 1 or 2 people and give me the RPM and speed readings starting at 3,000 RPM in 500 RPM increments all the way to WOT.
REMEMBER, The numbers I give you will be NO better than the information you give me
The only thing I ask of you is to come back and give me a report of WOT RPM and speed for my database.
H
L DRIVE 1992
1. 1992 Bayliner Capri L drive 120 hp force inboard
2. Length 20 ft x 7 width
2a. Recommended HP is 120HP.
3. Normally 6 people on boat and 10 gallons of gas
4. Use the boat for pleasure.
5. Year is 1992 Force inboard l drive 120 hp
6.
7. Manufacturer?s recommended Wide Open Throttle (WOT) range is 5000-5500
8. It have a dolefin
9. Diameter 13. Pitch 17. aluminum prop
10. WOT RPM and speed from my current prop is 3400 RPM speed is 35mi and 10 gallons of gas and 2 people were in the boat for test. Data and the speed was not by GPS.
11.The motor is Brand New not Rebuild the carburetor butterfly is opening all the way Motor is in excellent condition.
12.The RPM is to low 3400 recommended 5000-5500.
13.No damage on the prop
<br>
<br>
THANK YOU FOR YOUR TIME AND HELP!!
hwsiii
L, Spike is right 100% about the boat not doing 35 MPH at 3,500 RPM. If you are only attaining 3,500 RPM with a 17" pitch prop theoretically you would need to go to an 11" pitch prop to attain 5,400 RPM if your gear ratio is 1.93:1, please verify this. I am positive you don't need an 11" pitch prop, so either your tach is wrong or the speed is wrong or both are wrong.
WE need a GPS speed and you need to verify the tachometer is working right. Try turning the switch on the back of the tach to clean the contacts and make sure it is set in the right position for your motor.
H
hwsiii
Double Post
L DRIVE 1992
Thank you for replay. My Gear Radio is 14:27 by my operator's manual.
hwsiii
And that is 1.93:1 gear ratio, so you have a tach problem probably.
H
