Re: My idle screw is not long enough to set proper idle?
the screw should be on the step-cam....with the choke all the way open the step-cam should be on the lowest position and the screw in half way should touch it with ease...
http://www.oldcarmanualproject.com/manuals/Carbs/Rochester/2-Jet/1964Manual/index.htm
3rd row down 1st picture has the correct location of the step-cam also called the fast idle cam...
EDIT: I would probably keep to one thread for the most help....
http://forums.iboats.com/showthread.php?t=344222
if the engine wont idle with the screw in you either have a vacuum leak or the idle mixture screws are either set right or the passages are clogged...
pull the idle mixture screws out and spray carb cleaner in them and see if it comes out the mixture ports just under the throttle blades..
if the carb is one then open the carb all the way and look down the trhoat as you spray the cleaner in the mixture screw holes...it should spray out the throat...
the mixture screws should be at a base starting point of 2.5 turns out from all the way in...then set with a vacuum gauge...
