4.3 3rd time a charm
Thread starter- Joined
- Jun 23, 2009
- 12
OK guys I need some good advice here- just installed a new 4.3L GM Vortech w/ Holley 4BBL.600 CFM.
seems to run fine under 3000 rpms. timing is good all adjustmets to carb seem good - runs smooth---but when you do over 3000 RPMs acts like someone hit the kill switch-no sputter or nothin. no warning just dies.
this engine came with a Carter electric fuel pump P4389 6 psi max internal regulated.
the marina mech. is telling me that this fuel pump can not handle the 600CFM carb above the 3000 rpms. he says I need a higher pressure fuel pump 9 to 14 psi? I do not want a fire-- or is he correct?
just a little history when I installed this new engine of course as I said it has the electric fuel pump and oil pressure cut out switch. My other two 4.3L had a mechaincal fuel pump and an additioinal conventional fuel filer and fuel water seperator-- the new engine manufacturer told me that I had to much restriction and to throw the additional fuel filter away and just use the fuel/water seperator. I did and the problems still here.
lwhen I installed the oil pressure cut out swich and the oil sending unit-I had to add length to the 1/8 piping to fit them both--could that be a probelm that the oil cut out switch is about 4" high off ther block now?
Lastly-- is the fuel pump suppose to be mounted higher than the fuel/water seperator as they are about equal in height..
I think there is nothing wrong with this new engine ( God I hope not) I think it is in the fuel delivery.
any help ideas and what about a more PSI rated fuel pump.
PS- I aslo changed the fuel/water seperator just to make sure there was no reristions there., cleaned the fuel strainer on the Holley carb.
I am lost /please help?
Thanks
Grant
Thanks
Grant
