NIGHTMARE CONTINUES...any ideas?
raekmike
Re: NIGHTMARE CONTINUES...any ideas?
I think you really need to get that compression checked proper before guessing on the next step..Elimination of problems=piece of mind and a better game plan.
bluebrownie
thx... am gonna bring the starter to an auto parts store and have it bench tested.... is it likely they will do that for me? what information do they need to do that or will they have everything they need....?
-i am also gonna have my batteries checked there too
-am gonna get a new compression gauage.... and check my cylindars before i spend another nickle... at the end of the day, i will know how my batteries, starter and compression are...
again.... what do i need to do to get the starter tested at the auto parts store....?
SwampThing
I wouldn't bother taking the starter to an automotive store. Do you know what the specs should be? Under load? These starters overheat and get damaged extremely fast. Does the bozo at pep boys posses the proper faculties? As an ASE master mechanic for 20 years, that's living on the edge.
I'd rather get drunk and ride a unicycle on the interstate.
Besides the problem is with the gear not popping out to engage the fly wheel. That says internal starter problem to me.
Have you tried taking the starter off and seeing if you can pull the solenoid gear up by hand? Taking a pair of jumper cables and BENCH checking it after it's off the boat engine will tell you if it's good - partly. It should spin and the solenoid gear should pop up.
A quick check of the solenoid is to jump the two big terminals momentarily.
One is battery positive to the solenoid, the other is battery positive to the starter once the solenoid is engaged. Key on when you do this but be aware that you are going to turn the motor over and possibly have it start should the starter work properly. Take the usual precautions. Also do not continue to jump the terminals, the starter will stay engaged as long as you continue to do so.
When you turn the ign switch on, low voltage from the switch enters the solenoid and allows the solenoid to make the connection for the high voltage to the starter. It's engineered this way because you can't run high voltage through a switch without it burning up and being a hazard. This is the purpose of all relays. Since battery voltage is available at the starter relay anytime the key is on, engineers have also used it as a source the for other devices. Choke solenoids, etc. Basically anything that may be essential to have activated at the time of an engine start.
You can use a pair of insulated needle nose pliers. Every old Econoline van owner knows this trick, as Ford was the only auto maker that used the same style of solenoid. They failed just as much too. Do not replace a boat solenoid with an automotive one even though the marine one cost more and they look the same. They aren't.
With all of the above noted, the starters used on Force motors are notorious for a high failure rate. Mostly caused by operator error though. They have a tendency to over heat quickly from repeated attempts to crank a motor that won't start right away. This welds the internal contacts to the contact plate.
DO NOT BANG on it. This will crack the internal magnets that are epoxied to the inside of the case. It make work once, and it may cause a piece of magnet to dislodge and jam the starter after you're out on the water.
Before condemning your engine rebuild abilities I personally would double check ALL wiring to ensure that the proper wires are going to their proper locations, also the starter ground wires. Then I would disassemble that starter. Clean the inside and make sure that everything moves properly and reinstall it.
bluebrownie
just came back from the auto store.... they checked the starter, only providing juice.... everything worked, but no way to check under load.... battery is very good also...as we tested that... got a compression tester and inserted it.... turned the ignition and.....no more click.....but i did get a
continuous click, sort of like a door buzzer.....what the frick else can happen.... i am at the point of going to the marine shop.... but first, a case of ice cold beer...cuz this is insane....i have just about run thru my threshold of limits....
john from md
The continuous clicking is normally a sign of low voltage. Since your battery checked good, that leaves the main cables and the solinoid. If you jump from the battery to the most forward large stud on the solinoid, turn the key and still get clicking, it is a bad solinoid. If the starter turns using the jumper cable, your main positive cable is bad.
John
bluebrownie
"The continuous clicking is normally a sign of low voltage. Since your battery checked good, that leaves the main cables and the solinoid. If you jump from the battery to the most forward large stud on the solinoid, turn the key and still get clicking, it is a bad solinoid. If the starter turns using the jumper cable, your main positive cable is bad."
ok... so disconnect all the cables and use a jumper from the positive to the positive on the forward stud on the solenoid?
what do i do with the negative cables....conect one to the battery and one to the block?
bluebrownie
john...where do i send the case of beer?
bluebrownie
ok... put the jumper on the red terminal to the forward stud on the solenoid....clicking stopped....flywheel turned......NO plugs in during this test....SO then i put the compression gauge in cyl. #2 to get a reading...and the starter and flywheel bogged down...... seems like starter to me.... disconnected the guage and then turned the key and fly wheel turned.....
john from md
Those starters are easy to disassemble and check the brushes, commutator and windings. Most of these starters have been on the engines for several owners and don't owe anyone anything. Considering the kind of treatment they get, I'm surprised they last as long as they do.
I just bought a new one for mine from a guy called 14rebuilders. I believe he is in Ohio or WV but sells on ebay. I think I paid $74 plus shipping.
This was the best deal I found on the net and I recommend the company.
As far as your concerns about overheating damaging the engine, do the following.
With plugs out turn flywheel in direction of rotation with finger loosely over each hole in turn. You will notice suction then pressure or vice versa depending on which stroke the cylinder is on. If you get this and the flywheel can be turned with one hand, it is working fine.
John
bluebrownie
so you'd guess that maybe 2 problems....starter and positive cable? based on the last jumper test...clicking went away and starter worked, BUT THEN with compression guage in....flywheel/starter diddn't spin as well....am i understanding that correctly? why would having the gauge in one of the cylindars slow the starter/flywheel down?....bad starter?
john from md
The compression from the gauge being installed was why the starter slowed down.
You can cut the insullation a little at both ends of your cable to see if it is corroded. Since the jumper wire worked, it probably is.
You can try to crank the starter with the compression gauge installed using the jumper and see if it slows down. If it does, then, yes , you have two problems.
John
Frank Acampora
BEFORE you buy a new starter, replace the solenoid so you get proper voltage to the starter. It has been my experience that these starter motors even when in perfect operating condition just will not get enough power from jump starting and will almost always crank slowly.
SO: first put in a new solenoid , top off your battery, and then try to start with the key. If it still cranks slowly, now it is time to check the starter.
bluebrownie
brought the starter to an electrical repair shop...tore teh starter apart.... brushes disintegreated....they said likely was a bad ground from the battery...suggested rebuild the starter and check the grounds..... saying about 140 bucks to rebuild..... that sound reasonable/.....?????? i checked on ebay, showing new starters for 85.00 delivered....are those rebuilt ones'? or should i just have the rebuild done locally for the 140 bucks?
tx
john from md
I would by one from 14rebuilders on ebay. He is easy to work with, gives you a good product and backs it up with a no questions asked guarantee.
John
bluebrownie
HERE"S THE UPDATE:
brought the starter to an electrical shop that tests starters, alternators etc....they said my starter was toasted.... sooooo i bought one online...brand new, just got it and put it in.... turned the key and it barely turned the flywheel and then started to click.... the starter place said that it cooked becuz i had a bad connecttion...so i took out all the power cables, sanded, sanded the engine block for better contact, untightened and retightend every fricking nut i could find....and thinking the new stater is ok... and it minimally labors turning the fly and then stops turning it and begins to click.... i called the place i bought the startere from and they are gonna send me a new one.... but i am not convinced the starter is the problem..... i go back to my original problem and the head gasket blowing..... and could there be something stopping the fly from turning..? i can turn the flywheel by hand, get a good puff of air, ....any thoughts....
bluebrownie
play the trumpets, sound the bells and whisltes.....the motor started and i had 130 in ALL 3 cylindars.......so when i burned the head gasket, i ddin't screw up the cylindars....changed the impeller and water was spitting outta the pee holes, changed the thermostat, and the thermostat was working..... glad i talked mysellf off the cliff and stuck with it...THANKS TO ALL CONTRIBUTORS YOU ARE GREAT...... now i am off to have a ice cold frosty and a boat ride....thx again
what's next for this newbie....giving help to others on IBOATS....naw...not there yet...but someday!!!!
john from md
Glad it worked out for you. Enjoy the rest of the season.
John
