rs1lollie
Thread starter- Joined
- May 27, 2009
- 194
I have a ? on 3 blade vs 4 blade props, I currently use a 3 blade 14.25x21 prop for cursing, and I switch to a 3 blade 14.25x19 prop for water sports, I was looking at a 4 blade prop and it says to go 2 lower from your current pitch, so my question is if I run a 21 pitch I should drop down to a 19 pitch, is the 19 pitch 4 blade going to act like the 3 blade 19 pitch??? I'm looking for a in between prop so I don't have to change the prop all the time.
1990 Maxum 1800
7'2" beam
1900 net weight
1.84:1 alpha 1 gear ratio
3.0 mercrusier 181c.d.i.
135hp
max rpm 4400-4800
around 4800rpms @ 45mph w/ 21pitch
around 5200rpms @ 37mph w/19pitch
1990 Maxum 1800
7'2" beam
1900 net weight
135hp
max rpm 4400-4800
