I have a 2005 Four Winns 180 with a Volvo 4.3 with the SX drive. When I shift the boat into drive or reverse, there is a noticeable clunk.
I have actually only owned the boat for a couple months. When I first bought the boat, the clunk was present but the boat was idling high. I reduced the idle and that fixed the clunking. Well, its back, and its not the idle - I have it set to idle at about 650-700 and about 600 in forward gear (assuming my tach on the boat is accurate).
I have tried reducing the idle screw. It helps but does not totally elimnate the clunk. The problem is that when I reduce the idle screw, the boat runs really rough and I have a California Emissions carb that has metal covers over the idle mixture screws (appears to require total disasembly of the carb - over my head).
The prior owner changed the sterndrive lube, but I do not believe that he ever had the drive removed and services. I was hoping to wait until the end of the season to have the drive serviced.
Anyone have any ideas of how I could troubleshoot this issue without taking the boat in for service? Assuming it might be a problem inside the drive unit, any idea what it could be and what the damage (both to the drive and the wallet) could be to fix?
Thanks in advance.
Thanks in advance.
