I have a 1974 650 outboard motor. After pumping the primer bulb it runs for awhile then runs of of fuel and stops. I removed the gas filter and cranked the motor and fuel shot from the fuel pump for a few seconds then it started to blow a few drops and mist. I replaced the floats and cleaned the carburetor, replaced the diaphragm for the fuel pump and put a new primer pump bulb in the fuel line. It is still doing the same thing. Could there be other problems?
