cylinder drain valve
bayliner12
does any one know how to remove the check valve in a cylinder drain valve for a 1991 120HP L drive
pnwboat
Re: cylinder drain valve
I believe the drain valve assy is a friction fit in the drain cover itself. Unless it has been physically damaged, you should be able to take some carburetor cleaner and clean it out. The drain valves that I've seen consist of a ball bearing and a spring. Some of the early ones had a metal spring flap or something similar. If it is in fact damaged and all efforts to clean it out to restore functionality fail, then the only thing I can think of would be to drill it out, taking care not to damage the drain cover itself. Replacement valves are cheap and available. It may take some time to order one as they may not be in stock.
bayliner12
this one is on the out side of the engine head, the valves are just a ball type check valve, one of the balls is dameged and i need to replace the ball and seat assembly
pnwboat
This diagram should have what you need. Item 3 is a "T" fitting with a check valve. Item 5 is just a straight single fitting with check valve. I would call to verify if they have them in stock. I've ordered them before, but they always have to special order them. Takes a couple of weeks.
bayliner12
attached is a picture of the valvle, the 2 holes have a ball in them and are the check valve, that seat assembly is what im talking about
pnwboat
bayliner12
i found the part and ordered it...your right i wont get it until the first week of september, but i still dont know how to get the assembly/ seat out
pnwboat
I believe they're pressed in. I would imagine that they would probably be difficult to pull out since there isn't much of a lip, if any to get a hold of. If you could thread a screw into the valve assy., you may be able to pull it out that way. Heat up the drain valve cover to expand it and possibly make it easier to extract. Don't use too much heat though. Another option would be to try drilling, but you have to be very careful not to damage the drain valve cover itself.
bayliner12
I was thinking maybe an easy out?
moparman
go the screw route,as this would be the less likely to tear up something else. Since your putting pressure on the seat only[via the sheet metal screw],you run little risk of hurting other pieces. Just my 2 cents worth.ANT other suggestions??? MOPARMAN
