64osby
- Joined
- Jul 28, 2009
- 6,826
My early 5HP early 60's Sea King has issues, Bought it used at a garage sale. The owner said it worked great
It has no serial number but it is a 60-63, equal to a J/E 5.5
I replace the coils adjusted the points and put a new impeller in. With a little tweeking she fired up and ran, (in a water tank
Looking close, it was leaking fluid and air out the side of the housing at the seam where the crank is located. So I tore it down and this is what I found. Someone had tried to pry the casing apart with a screwdriver and put some pretty nasty gouges in the casing. I can only assume they hadn't taken the 2 bolts out behind the intake before they tried to pry it apart.
I cleaned it up as best I could put a small amount of gasket sealant on it and put it back together. She fired up and ran, but not good. I tore her back down. The sealant had plugged the holes on the bushings. I removed the sealant and put her back together without any. She fired right up but now she still is leaking at the casing.
I don't have a manual, but have looked at parts diagrams on line. I don't see any reference to a gasket, and it would make the spacing at the bushing too wide.
Any ideas on how to fix this??? What, if any sealant should I apply? Do I mill one side down and use a gasket? Or do I live with a leaky motor?
