1995 Mercury Sport Jet 120
sj120mi
I just aquired a 1995 Euroline Cyclone Jet Boat. It has the Sport Jet 120. Everything seems to work fine. I was wondering what routine maint needs to be done on these. I changed the pump oil(two screws by water intake on bottom of boat) Is there any other places to lube or change out fluids?. It is and older boat and I want to make sure it lasts as long as possible. Anything I should look out for? Also, what about winterizing, I am in Michigan it will be stored in an unheated garage. It will be below freezing for the better part of the winter. If anyone has the manual for this, that would be awesome to have.
Thanks
kantush
Re: 1995 Mercury Sport Jet 120
That's all there is just be sure to stabilize your fuel, it is self draining so not an issue. Remember never run it out of the water you'll kill it pretty quick
