1971 johnson 100hp HELP!!
python20
i have a 1971 johnson 100hp i dont know much about boat motors period i bought this boat took it out once and it seemed like it was flooding very easy but when running it ran great . well it sat in the driveway for about two weeks went to start it up before takin it back out and it sputtered a few times like it was gonna start then nothin now all it will do is crank. i know its getting gas and i checked the spark it is getting spark but very minimal checked the power pack and all wires except the blue one that goes to the coil are reading around 11.6 im at a loss idk what to do please help!!
SparkieBoat
Re: 1971 johnson 100hp HELP!!
you need to look at your carbs while it is running and see if gas is flooding one of them..you may have a stuck needle valve. you should only see a misty spray of gas in the carb when you throttle it up. If you have a carb flooding it will usually puddle in the bottom of the carb opening when idling.
Good Luck
Sparkie
Daviet
You said this boat is new to you, could you explain you start up procedure? I know it sounds silly but maybe thre is a problem with the way you are trying to start it.
python20
yes i squeeze the primer bulb till its hard, pull out the manual choke, put the start/run lever on start and turn the key once it starts push the choke wait till its warm and put the lever on run. i mentioned flooding because it was a problem i was having and i believe it was happening due to lack of spark, i am just lost because if the amplifier was shot i should have no spark at all, but that is not the case i do have spark it is just very minimal ie i had someone crank the motor over while holding a metal object in the plug wire haha dumb i know but effective, i should have recieved a pretty good shock and it barely tingled and even holding a brand new plug up to the block to visually check for spark it is very minute i checked this coming from the coil and from the plugs same result both places VERY LITTLE spark after that i tested voltage to the amplifier assembly all wires except the blue one leading to the coil read 11.6 the blue one showed nothing how is this possible and what do i need to do to fix my boat ? any help at all is greatly appreciated
SparkieBoat
i have a handy little tool i got from a local auto parts store that measures your coil power, it was cheap and better than looking at a sparks plug. it has a ground clamp and the other end goes into your plug wire with a threaded rod that can be shortened or lengthen to determine coil power. Coils are cheap enough and should be replaced every 5-10 years anyway. Also replace your plug wires. and check all electrical connections. I put a dab of grease in each connection.
Good luck Sparkie
F_R
And just why do you think you should have a measurable voltage on the blue wire? That wire carries about 300 volts in extremely short pulses, too fast for your multimeter to respond to it.
Your amplifier is working. Your breaker points are working, although we don't know about the gap, etc. But they are at least triggering the amplifier.
So.o.o.o.o, if your spark is weak, either you are losing it in the distributor or the coil is defective.
Do this: remove the coil and unscrew the wire from the distributor cap, then remount the coil and reconnect the blue wire. Rig up a spark gap off the end of the threaded terminal that came out of the distributor. Make that gap about 3/8". Now crank the motor and see if you get a spark across that gap. If you do, you are losing it in the distributor.
python20
i am getting spark from the coil it is just very weak i also noticed two wires coming out of the throttle/ignition box that are not connected to anything could this be affecting anything or what are they for ?
