Starcraft owner finally? Yes!
wvmedic
Re: Starcraft owner finally? Yes!
Sounds good Rick.
Jeff.
CheapboatKev
:DAlways glad to assist!:D
That newer starcraft paint scheme is cool...I wouldnt have the patience to pull it off
CheapboatKev
Jeff as far as I know the weekend of June 26th is the date for the get together :D. We can pick you up in the convoy comming from Louisville if ya like :D.
Rick
swing down here while your at it!! lol
Rickairmedic
Hmmmmmmmmmm lets see head out of Louisville east on I-64 towards West by God Virginia grab Jeff and then on out I-64 to Virginia . Um Kev I dont think we will cross A1A or I-95 anywhere in that rought :D. We could meet you near Jeffs though :D.
Rick
wvmedic
Kevin the paint for me shouldn?t be too tough. Someone else already did the ground work, I just have to tape it off and switch colors. :DThat is after it is after the prep wok.
Jeff.
Rickairmedic
LOL Jeff just remember tape it off paint it and pull the tape all in the same day :D . Trust me on this one oh yeah and use the green automotive tape Autozone carries it :D.
Rick
wvmedic
I hear that Rick, I wasn?t going to make any reference to that.
Jeff.
wvmedic
Just a comment on the trip, it went well my truck got 19 mpg on the way up. But it only got 13.4 mpg on the way back, I?m hoping the soft car tires and the boat being higher in the bow than it should have been was the problem. That is quite a drop in mpg, what do you guy?s think? Could the soft tires and the boat not being level cause that much of a drop in mpg?
Jeff.
Rickairmedic
Jeff I would lean towards the soft tires . The bow didnt look all that high to me in your pics. You might try to weigh her if you have a truckstop nearby just to see if theres any extra water weight in there as that wouldnt help either.
Rick
wvmedic
Yeah Rick, I?m leaning toward the tires being the big issue. Man talk about a soft ride, I initially thought the probably only had about 15 psi in them but we checked and they were at 32 psi.
I agree the bow isn?t that high, but I think I will flip my draw bar over and drop it a few inches.
And yes I will weigh it, there is a Pilot just across the river.
Jeff.
Rickairmedic
Jeff what year is your new toy I can probably get the dry weight for you on it if I know the year :D.
Rick
CheapboatKev
any kind of wind conditions on the way back? may have been driving into a headwind, thus dragging the MPG down a bit?
Andy in NY
when i brought my mfg to connecticut, going through the mountains into a headwind... got 13.5 mpg when i normally get around 19 mpg.
but there were 2 other factors too... the fact thaat the boat probably weighs a few hundred pounds more then it should... and its shaped like a brick.
oh and my rear end was failing on the way there and i didnt know it. blew it up by the time i got there.
wvmedic
Rick it is a 1980.
Jeff.
wvmedic
No Kevin no head wind to speak of.
Andy I think the MFG would be a little heavier than the Starcraft.
Jeff.
Andy in NY
Jeff.
dry weight was stated by MFG as 650... and a merc 50hp only weighs about 175...
but like i said i think i was carrying some extra baggage so to speak.
wvmedic
Andy, wow I would have thought the MFG would have been heaver.
Jeff.
Rickairmedic
Jeff the 74 brochure shows the 18' SS at 910 pounds and the 77 Brochure shows it at 844 pounds. That should get you close and thats dry weight for just the boat.
Rick
Andy in NY
also gotta remember jeff that you dont know whats lurking under that deck. could be lots and lots of waterlogged foam. waterlogged deck and transom can add up to alot too.
