95 70hp force no spark
bullet09
Put the boat in the water fired up fine then i got up to move something and the boat idled out, tried to fire it back up but would not go. checked the plugs and see they had no spark. Any suggestions on what to do from here.
Jeremy90bay
Re: 95 70hp force no spark
did you somehow possably break the kill switch or the ignition switch. sounds strange for it to just die like that.
perna00
Could be either the switchbox or trigger if you lost all spark. Otherwise, could be a simple wire/electrical problem.
foodfisher
Does it have a neutral safety switch? Did you bump the throttle just enough to activate it?
