whatasteal
Thread starter- Joined
- Jun 7, 2009
- 13
First I would like to thank everyone on this forum for all the great info. I have not posted much because from searching and reading I have solved most of my issues. ie bad starter, dist sensor, etc.
Current issue started a few weeks ago (weekend boater) with low rmp, 3700, at WOT. Should be between 44 and 48. I have covered almost everything on the wot issue list in the adult section. Replaced cap rotor wires plugs 2 fuel filters, anti siphon valve, added fuel/water separator, boat never had one, fuel pressure/vacuum ok, timing ok, compression ok, oil level ok. This past weekend I also noticed it was overheating at very slow speeds.
So, would these two issues, low wot and overheating, lead to impeller/shutter issue? Not sure if I would tackle these as my BYM skills may not be good enough for dropping the drive.
