stormtracker
Thread starter- Joined
- Sep 16, 2008
- 10
Hi all. If someone can help me; I need to turn up the idle on my 1989 Johnson 88 SPL. It runs great at high speed but sometimes stalls out at idle, and when shifting into gear. I see several adjustment locations, but not sure which is the correct way to adjust the idle. The attached picture shows how it is at idle, at least before I started messing with it; Which I started to do originally to bump up the water pump flow at idle, as the overheat alarm would sometimes come on at very low speed. And it's a brand new water pump, and thermostats that I put in.
From reading other threads here, I believe the red arrow points to the idle adjustment screw, however notice how far from the stop it is. I have to turn it almost all the way in to make any adjustment at all. And doing so also, with every turn, moves the long threaded rod (green arrow) under the flywheel. What does that do ? Is that the timing advance adjustment ? If so wouldn't it set that out of whack by advancing it way too much ? Then there is the thumb wheel adjustment, (the white arrow). Should that be adjusted ? And last but not least the thumb wheel adjustment on the cable itself.
Any help or thoughts would be appreciated.
Thanks.
KM
Thanks.
KM
