Re: how to install outdrive
Some times the drive stops at the o-rings. take the drive off and remove the o-rings and remove any grease that is in the grooves.Clean it good.Reinstall the o-rings and spray WD-40 on them.Make sure the gimbal is clean.Then make sure the alignment is correct.You might need a little bit of force to push the drive on.Something makes the o-rings swell or the tolerances are too tight.
You might need a 2x4 and a big hammer,remove the back cover and use the 2x4 and hammer(had to do this a hundred times on different drives).J
