bill200xri
Thread starter- Joined
- Aug 14, 2009
- 10
I have a '94 200 xri, S/N 0G060988, with a problem that prevents from accelerating over 3500 rpm. I have no problem accellerating out of the hole, and can run on plane at 3000 rpm with no issue. I ran thru the Merc manual to troubleshoot. Fuel pump puts out 39 psi, but I did not check it at speed. Should I? Anyway, the fuel system troubleshoot concluded that it was an electrical problem, although I did not do in-line pressure checks...just checked the high pressure pump at the zerc fittting.
Resistence checks on all component checks good. DVA check on coil input voltage good. Spark test appeared good, but not sure with the visual test using spark gap test tool. Spark could be weak. Could be a coil or two? If I had a bad coil, would I know it at lower speeds? Timing at idle is 2-degree ATDC, timing at 3000 rpm 18-degrees BTDC. Timing is steady at all speeds up to 3500 rpm, where it starts to move around as the engine speed changes (revs and drops, and if I give it full throttle, it chugs). When the speed revs to 4000 rpm for a split second, the timing was ~22-degrees BTDC. Anyway, the manual troubleshoot step indicated that I should now look at the fuel system (back to square 1).
Can anyone give me tips on what to check next?
Thanks,
Bill
Thanks,
Bill
