2008 tahoe 215-tach
medicfireman
i posted earlier on the poor performance and i followed a wise mans advise on checking the tach.....there is a mark for 4c,6c,8c--which i understand but mine was set on 6p-there was also a 8p--i moved it to 8c was that correct?
thanks
hwsiii
Re: 2008 tahoe 215-tach
LOL, I have to assume you have an 8 ylinder and it was set on 6 ylinder. That will ertainly make a differene. :eek:
H
medicfireman
no it was set on the pulse settings--- it goes 4c,6c,8c, and then 6p and 8 p
hwsiii
Lord, get me some numbers for WOT RPM and speed.
H
medicfireman
5.0 mercruiser- 22ft deck boat
with 6 people, 40 gallons of gas and 20 fresh water
23p alum- 3000 rpm at 31-33 mph-wot
19p alum-4100 rpm at 44 mph -wot
that was before i changed the tach, i am going boating in the am....
the goober at basspro said that changing pitch would not help- that a 23p was what i needed....i am thinking 17p 4 blade...i am just curious about that tach issue---i will post tom after i run it
4C, 6C, and 8C stands for four cylinder, six cylinder or 8 cylinder. 6P and 8P stand for six "pulse" and eight "pulse". These last two numbers refer to a tach that is being driven by stator pulses. Tachs driven from the ignition system rather than the a stator are sensitive to the number of cylinders the engine has. If you have a 4 banger it should be set to 4C. 6C for a six popper and 8C for an 8 thumper.
hwsiii
Silvertip, you are definitely right.
H
hwsiii
Medi I will be ready to run the numbers when you get them.
H
medicfireman
alright--
the changes were dramatic---
21.5ft tahoe deckboat
5.o mercruiser-220hp
6 people and 30 gallons of fuel
19p 3 blade alum mercruiser prop
3000 rpm's 26 mph
4500 rpms wot at 47 mph
should i still get a 19 4 blade--hole shot is ok- but not the best
what is a good sternlift aluminum prop--thanks for the help guys
hwsiii
Medi, my reommendation is for the Soloas Rubex 4 blade aluminum prop in the 17" pith as it will let your motor turn right at maximum RPM of 4,800 and it will make your hole shot superb and you will be able to arry a muh greater load at higher speeds than the prop you have now. It lifts the stern and has enough blade surfae area to hold the stern up and pull up skiers effortlessly.
It is available at Iboats and here is the information for it.
Price: $126.98
You Save: $30.97
Compare: $157.95
Discount: 19.7% Off
Add RUBEX 4 Aluminum Propeller Prop: 9513-145-17 Hub: RBX-102 To Your Cart
Propeller Specifications:
SKU:prop #9513-145-17Hub #RBX-102
Manufacturer: Solas
Brand: RUBEX 4
Material: Aluminum
Diameter: 14 - 1/2?
Pitch: 17?
Blades: 4
Rotation: Standard (Clockwise)
Usually Ships Within: 1 Business D
H
medicfireman
thanks again for all the help---do those numbers sound better.....
it it that uncommon for a deck boat to need that low of a pitch since it came with a 23p----but the boat runs great so i cant complain-
agian thank u
hwsiii
Medi, if I were you I would all Tahoe and ask them what pith they reommend for your boat with the motor you have. But if your motor is putting out the horsepower it should be, it is going to require the 17" in a 4 blade for the low end pulling power and to keep your RPM at the top of the manufaturers reommended RPM range. If they say anything different then ask them exatly whih make and model of prop as well as pith and diameter. Beause if they say it is different then they know what exat prop they used for those results.
How does that sound, it only takes a little bit of time.
H
medicfireman
i did call them- that was what started all this,,,they said the mercruiser 5.0 called for a 23p--they said it didnt matter what boat--can u believe that..i am sure the 5.0 would turn a 23p on a 1500lb runabaout but this is a 4000 lb boat...
then they went as far as to say that decreasing pitch would not change rpm's...
this is my 7 th boat and i am not new to props- but i am new to i/o power plants..i would rather take advise from you guys over some pencil neck that doesnt know port from starboard///anyway--thank u for the help--i will send the numbers to u when i get the prop
hwsiii
LMAO, you are right, he is an IDIOT.
H
