I purchased a used boat 1995 Celebrity 180 with a 5.0L Mercruiser and Alpha 1 outdrive at the beginning of the season. The boat has been flawless all season. I noticed my temp gauge stopped working, so I replaced the sender, and got it working again (also noticed the fuel line was leaking because it was loose, fixed that too). While I was at the lake testing it out, I noticed that at WOT, the RPM would get to 5500. WOT RPM used to always be at 4500 RPM, so I backed it off to 4500, engine sounded alot slower that in usually does at that RPM and the speed also dropped. Used to be 45mph at 4500, now it's about 30. I can still get it to 45mph at WOT, but the RPM is way too high, 5500. What would cause this? Bad tach? Can the drive be slipping? The lake is at 7000' elevation, prop pitch is 21. The only thing I did was add some drive oil before I went out. It was just under the full line in the reservoir, so I just put a tiny bit more in there to get it to the line.
