clemson726
- Joined
- May 4, 2009
- 8
I have a 2001 Yamaha OX66 200hp with a hot foot that has suddenly developed a hard shifting scenerio. I've had this boat for 3 or 4 years and never encountered this problem. I had replaced a water pump so the foot has been off, but have had it out a couple of times since then and it shifted fine. Last weekend i was on the water and it was quite rough due to a lot of boat traffic. I had come to an idle in a congested area and was shifting from neutral to forward numerous times with no trouble. I stopped for a couple of hours, then started the boat up and when i tried to put it in reverse it seemed as though it was in a bind. It eventually went in, then when i tried to put it in foward, it again acted like it was in a bind. After that one time, it went in forward just fine but still binds going into reverse.
So this morning i pulled the cover off and found a bolt lodged around the shifting rod that goes through the lower cowling. I took the bolt out knowing that was the problem, but it wasnt. It still wouldnt shift into reverse. I removed the linkage and the hand shifter was smooth. I tried to hand shift it at the motor and discovered that it would bind going into reverse until i turned the prop a bit with my foot, and it would fall right into gear. It would then shift fine into reverse, but bind going forward until i turned the prop a bit. It acts as though it's jumped a spline in the foot or something but i cant figure out how it could do that. Any thoughts?
