I have a 1993 MERC 4.3LX with an Alpha Gen 2 drive. The last two times out I have noticed that right after i slow down from high speeds (close to WOT) & then go to throttle back up again, it feels like im driving a car with the clutch slipping. The engines RPM's are climbing but the drive/prop is not turning fast enough or keeping up with the engines RPM's. After a few seconds or more, the drive/prop does catch up to the engines RPM's and then i have no problems once im going. I have never heard any clunks or smelled burned rubber and there is never any strange noises when this happens. I do have my drive trimmed up a bit but not to the point where its at the automatic stopping point before it goes into the trailer tilt mode. I didn't think it was prop Cavitation because i never hear the prop coming out of the water or feel the prop slipping in the water once im at a higher speed/rpm. Its only happening when i come off from high speeds and then throttle back up again. Any ideas what this could be ?
Thank You
Thank You
