83Evinrude
Thread starter- Joined
- Sep 3, 2008
- 290
My boats Faria trim gauge will only read all the way up now, last time out it worked just fine. When you turn on the ignition key, the trim gauge moves down about a needles width no matter the drives actual position but is still basically showing full up.
I checked under the dash for a loose wire and did the same on the engine but don't see anything at either location. All fuses are also good. I also tried adjusting the gauge at the sender and got no response. After taking out the mounting bolts I can rotate the sender but can't seem to pull it free of the gimbal housing.
When we first purchased this boat I was trying to get the gauge to more closely match the drives position (full down reads full down) and played with adjusting the sender a bit. I found there was a very narrow range (where it was to start with) where the gauge would read at all. On either side of this range, the gauge would always go full up. I set it back to the mark I put on it before adjustment and its worked fine until today.
All advice appreciated.
