how should i fix a small gash in my fiberglass boat?
vision1200
Looking for some tips about what i should do. its about a quarter size indent in the fiberglass. it does not go all the way through but it still leaks.
vision1200
Re: how should i fix a small gash in my fiberglass boat?
yeah i can get a picture of it tomorrow to post. its white where the indent is. i have a fiberglass resin gel to use and strips also.
WAVENBYE2
I went up and edited and put acouple of links to look at and read about. Welcome to Iboats! Always good to have new people here, Lots of guys here happy to help!!
vision1200
with the marine-tex would i still need to use a fiberglass strip too? or just fill with putty.
WAVENBYE2
A quarter size hole, You should make sure it's cleaned real good and it should still bond, you said it was leaking too?
vision1200
yeah it is leaking. i was planing on putting on a new gel coat all over and repainting too. this is the first boat i have worked on,so i figured i would get all the advice i could before gettin into it.
WAVENBYE2
Have you been to the "Boat restoration and Building" forum here on Iboats?? You should go there and read up on some of the work done:) also look up, see the "search" click on that and type in "marinetex" and you can read what other people have done in the same simular situation, very informative!!
vision1200
ill check it out. thanks for your help.im gonna look in to the marinetex. thanks for the advice
WAVENBYE2
No problem!! Take pics and show us, We all like to read and see what and how you did it, all of are here to help or talk or whatever, So ya'll come back hear!!
