1986 Johnson 40hp Stalling
wolfman35
Ok I have a Johnson 40hp outboard 1986 VRO2 that will only stay running if I keep the choke engaged. I have searched the forum but can not find an answer to the question of should I be able to blow through the pulse limiter both ways or just one? I can blow through either side of mine. This motor has been sitting for a few years. I have installed a new tank and fuel lines. The lower carb was plugged up and not getting fuel so I removed the bowl and cleaned out the needle and seat and there is fuel now in the bowl but still have the same problem. Thanks for any help.
