1957 big twin missfiring, stumped!
schneider244
I have a 35hp '57 big twin which seemed to be running well except for the occasional missfire. I rebuilt the carbs and set the points visually inspected the coil and observed good spark on both plugs. Test ran the engine in a tank, started right up seemed to run well.
Mounted it to the boat and went for a cruise. The engine started well but underload wouldnt go above high idle and would soon die out. I ended up having to paddle back to the dock.
Got the boat home and put the engine back in the test tank and it ran fine just smoked more than usual. I then pulled the top cylinder plug and it immediatly died out. Put the plug back on and restarted, pulled the bottom and nothing. it ran exactly the same, not even a hiccup. it seemed to run fine without the bottom all through the rpm band..
Afterwards i noted the top plug was quite hot wheras the bottom relatively cool. both plugs spark, i got a fairly good shock from both plugs when removing the boots. and the bottom plug gave a familiar tick tick tick sound when removing and replacing the boot which leads me to believe it isnt an ignition problem, however they both have good compression................
im stumped
does anyone have any ideas?
THANK YOU
bktheking
Re: 1957 big twin missfiring, stumped!
Don't these motors have an adjustable high speed jet? You don't mention making any adjustments after rebuilding the carbs.
Faztbullet
Swap plugs to see if problem follows plug, if so its a bad plug. Also check that they are correct plugs and piston has not closed gap on plug. You should have J6C plugs installed
lindy46
Sounds like the coil to the bottom cylinder is bad. Did you test spark with a tester or just look at the plugs? Those motors will idle fine with only one cylinder firing.
schneider244
I didnt test with a tester, I figured I saw a spark and that was good enough. Is that not an accurrate assumption?
I have about 10 j6c plugs laying around and none work on the bottom cylinder.
I dont think the high speed jet would be causing this as it wont fire at any speed, plus there is only one carb for both jugs.
bktheking
We had this problem too on a 64 big twin 40 , had spark but nothing on the plug, one of the wires wasn't in far enough on the coil, once we removed everything and pushed it in farther is started working again. The other thing is grounding the magneto, check for frayed wires under the flywheel.
bktheking
Also, you could try swapping the coils around as a last resort.
schneider244
im on my way out now to pick up a balance puller so I can get the flywheel off. i have a pair of new coils sitting around I will try them out.
schneider244
ok, got the balance puller, removed the recoil starter, the peep hole cover, and the large main flywheel bolt. Attached the puller and started pulling the flywheel, the darn thing wont budge! am i missing some other bolt somewhere?
thanks
tx1961whaler
No. The large nut is all that holds it on. You're gonna have to really, really tighten the puller to get the flywheel off. Hopefully you are using Grade 8 bolts in the puller to pull it off. Stripper bolts are the best, but more difficult to find. Lesser bolt are going to snap. An impact wrench helps, if you have one.
Your problem is most likely the coils. The coils of that vintage crack and fall apart. Clean and regap the points while you're under there.
lindy46
thanks
Leave the large nut loosely on the shaft, so the flywheel doesn't go flying when it releases. Tighten the center bolt on the puller, then give it a good rap with a hammer. Tighten the bolt a little more, another rap, etc. until the flywheel releases.
CBGale2
For sure leave the nut on a few turns, I got that tip when I did mine and was sure glad I did. I thought for sure when that thing let go that something broke off, scared the heck out of me. :eek:
asdasc
Yeah, they do idle really well with one cylinder if you adjust the carb right. Boy was I surprised when I changed the plugs one day and found I had twice the power. I had to retune the carb again, but what a difference. I figure I ran it over a year on one cylinder and it purred like a kitten.
