apeephere
- Joined
- Aug 27, 2009
- 5
Hi guys .
Usually I just sit and read but since I developed this problem I decided to join and ask for help ,so here goes.I have a 1988 Maxum with a 88-Force 85 HP Outboard Motor.I have had a problem starting and idling once it warms up and usually dying as I put it into gear so I replaced the fuel pump,siphon / pump ball,and even disconnected from builtin tank and went to portable tank and installed an inline filter so I could see the gas going thru.Unfortuneately I did all this before doing a compression test.I have 125 HP in #1,& #3 and 85 in #2.This was done with engine cold(warm weather,engine not started for about 3 hrs)and not with WOC-which I realized was the wrong way of doing it after I had removed the head.But with a difference like that in one cyl. shouldnt it indicate the same? Head looks fine ,pistons and walls all look in great shape -no scoring or anything and no breaks in the gasket. I am thinking possibly rings but figured Id ask as I did so many things incorrectly. Should I reassemble head(can i use the same gasket?)and redo tests?Or do you think its rings also and I should just continue and replace the rings? I only have a Selock Manual but have ordered the Clymer and am awaiting its arrival.Any thoughts would be appreciated!
