Hello, I have a 1969 omc gm 3.0 straight 4, I brought this boat from someone about 4 months ago. The guy I brought the boat from new nothing about it. It needed a new floor and seats. So took it home tryed starting it no spark. So I replaced the coils, points, spark plugs, wires. Then it worked took care of that problem. Then we noticed the boat was not sucking water figured out it need a new impeller so bought a new one of those and that problem was fixed. Then we took it out on the water would not accelerate past 2rpms. It goes to 2 rmps then does nothing. So, we took it home I changed fuel lines, filters, had carbs rebuilt, made sure gap was right and points where correct to book, etc. Also set timing as book said at least I am pretty sure, took the prop off and took it to a prop store to see if anything was wrong with it and if it was the right one, nothing wrong with that. So after all that we took it back out and nothing still does the same thing. In my driveway with muffs on it will accelarte but with load it will not go past 2rpms. You go to push the lever down to go faster and the lever goes down but rpms stop at 2rpms. Out of ideas, Any help?
