Ive asked the question before and got mixed reviews about adding a jack plate to my 2005 SX180 Skeeter with a Yamaha 115. After speaking with one of the local marine shops, they said I would benefit from adding one so I added a TH Marine 5" offset Pro High Jacker HP. They brought the motor 3" above where it was located originally. My current WOT RPMs are right at 5400 with a 21 pitch 3 blade stainless steel propeller and 49.3 GPS MPH reading versus the original 47 GPS MPH reading at 5000 RPMs. Ive read on this forum that the optimal RPM range is 5800 even though the Yamaha specifications for the motor are 4500-5500. Would I benefit from going to a different pitched prop? I know decreasing the pitch will add RPMs and increasing will reduce RPMs so I want to make sure I am operating within the peek performance range of the motor. Any suggestions on this would be greatly appreciated.
Last but not least along the same lines, while having the jack plate installed, larger jets were added to the carburetors which to my understanding were to basically bring the motor up into the 130 range. Did this have any impact or was I just taken to the cleaners on this one? Thanks and appreciate anyone's feedback..........especially on the later of the two.
