Re: anybody try useing alumaloy to repair an aluminum prop?
Leave the prop repairs to the pros - i.e. a good prop shop. Adding something like that, you would probably change the balance of the blades, and the stuff most likely isn't strong enough to handle what a prop goes through. If the prop is out of balance you can do serious damage to your lower unit - which will cost a lot more than a new or rebuilt prop.
